Performer rpm question
StJamesAuto
Will a performer RPM intake and 4 barrel Holley fit with no hood clearance issues? Thanks!
blubuckaroo
Grease Monkey
Ridgefield WA
I doubt it unless you leave the air cleaner off.
My Preformer just barely fit with an extremely low air cleaner. Only 1/8"-3/16" of hood clearance.
Now, if you have a body lift, it just may fit.
cs_88
I think with a 302, stock hood and no body lift is doable but would be very tight. Your choice of air filter/cleaner would be key. I'm thinking a drop base air cleaner with a 2" filter maybe.
Good luck.
5001craig
I have this same question and have since I had my engine built.
I will be installing this intake on a 351W with a 2" BL and WH extreme motor mounts.
I'm thinking I will need a new hood with additional room...
triracer67
I'm running the performer rpm, with edelbrock 4 barrel on my 289 and it fits. Drop base 14"x2" air cleaner.
