Pertronix Ignitor vs. Ignitor II
jerry
Bakersfield, CA
Anybody running the Pertronix Ignitor II? How do you like it, any problems, etc?<br><br>Already read the thread on the regular Ignitor, looks like mixed reactions on that one.<br><br>Thanks,<br><br>Jerry
FL
I have two other old cars ( not Broncos) with Pertronix Ignitors, one of the old ones and one of the newer Ignitor II.<br>Both work fine. The older one took a little more to install as you had to add a magnetic ring to the distributor. <br>The new model does't need the magnet. You just install the module musch like putting points in. <br>Then evry time you start you have to count to 4 after turning the ignition on and before cranking to give the module <br>time to sync up. I also use the Pertronix coil with the ignitor II.
