I don't have the dimensions offhand, but they might be listed in rock auto or Centerforce.
The good news though is it for the most part all the V8 family of Ford engines including the Windsor use the same part. Are you running into a problem? Or just looking for confirmation?
If you're using a Ford transmission and a Ford engine it should work. If you're using your Ford engine with something like an NV3550 you would need a custom bearing from Advance Adapters.
Or is it that you just have a random bearing and wanna make sure it's for your engine?
