supermottl
Hey alll. Finished buttoning up the pinion gear on my D44, and it feels a bit tight. When I torqued down to 100 ft/lbs with the old nut, I checked preload and it was less than 40 in/lbs, but more than 25 in/lbs, and then loosened up more and I spun it, playin' with it
Now, I used the new pinion nut, torqued down to 100 ft/lbs, then bumped the nut with my impact wrench a few times (Max torque of impact wrench is 250 ft/lbs) and now the pinion preload is much higher.
Should I worry?
Basically, What should I do, I'm at a loss. Run it? Will it loosen up a bit? Stick another shim in there?
Should I worry?
