Brent13
All,
Changing R&P in the 9". And ready to set pinion preload. One slight problem, the new bearings are obviously a press fit onto the pinion shaft. Well, if I don't get the spacer correct the first time, I will have to pull the bearing off to change shim stack. I never get that lucky the first time. Anyway, just so happens that the old pinion bearing does slide onto the new pinion shaft. Can I use the old bearing to set pinion bearing preload? Is this acceptable? If so, once I get it right. Will disassemble, remove old bearing, replace with new bearing, and drawing new bearing on with the pinion nut. Sound like a good plan?
Thank you
Thank you
