Thermal coefficient of expansion..
TexasBronco said:
Ok now how do i go about installing the new drop pitman?
This is going to sound a little weird, but it works:
1. Make sure the wife (or girlfriend) is out of the house.
2. Heat up the new pitman arm in your oven for a few minutes until it's nice and toasty.
3. If the steering box is off the truck, put in a big plastic bag and stick in the freezer while the pitman arm is "baking." (Of course, you could just leave it outside - it's going to get pretty damn cold out there in West Texas by tomorrow.)
4. Put on some gloves, grab the pitman arm, run out to the truck, (or take the steering box out of the freezer) and it'll slip right on the steering box splines. Tighten down the nut before the arm cools and the shaft heats up much.
5. Run back inside and open a kitchen window (see #1, below).
You want to make sure your significant other is away while you do this because:
1. It'll make the oven (and the kitchen, and after a while the rest of the house) smell pretty funky.
2. They'll think you're crazy and take every opportunity to tell you so.
