Pitman arm swap
mdainsd
San Diego
I thought I was nearing the end. I changed the stock manual steering box out for a Borgsen (SP?) Power box.
The original pitman arm fits the new box but is biased to a left hand turn. Cant reclock the pitman arm as it has keys (filled in splines) that match the shaft on the box.
Do I need a different pitman arm? Is the power box assembled wrong?
mdainsd
mdainsd
San Diego
The good thing is now I know its a real problem not something be caused by a hidden something. Thanks for the suggestion.
Sometimes a box might be keyed differently, but usually a Pitman Arm is keyed differently. Different ones sometimes for different vehicles.
First thing first though. Make sure your box is actually on-center.
If it’s still offset, you can grind the splines out like suggested, or since the metal isn’t all that hard to begin with, take a triangle file and literally just create your own splines. That’s what I did.
Just cut a notch in the center of the key splines and then put it on any way you want it.
Joshuasnr
Little Rock, AR
Many builders end up using a drop pitman arm during this swap if they have a lift, as it solves the indexing issue and corrects steering geometry at the same time.
Are you running a suspension lift, or is the steering geometry still at the stock height?
mdainsd
mdainsd
San Diego
Thanks. I bought a pitman arm that is fully toothed. That and a three way adjustable tire rod/drag link assembly. Should be good to go now, except chassis went to the body shop yesterday to get the body married to it.
