What do you guys like running better. I have an AOD and I am not sure if it is worth it to keep messing with my column shift linkage or just throw a Lokar floor shift in when I swap out my engine this month.
The Lokar floor shifter is nice, but I like the Art Carr even better. You're less likely to bump it out of gear. I wouldn't hesitate to put another Lokar in a hot rod, if I get to build up another (I helped my brother do a 70 Nova, and we put one in his) They do work well, but a slight bump and you're in neutral. The Art Carr shifters are being recieved with rave reviews in the rock crawling world for being smooth and reliable.
I may one day put one in my rig, but for now, the column shifter is doing me good. I'm still running a C4.
It all boils down to personal preference. Do what makes you happiest, and you'll never be wrong.
I am planning on putting the 4R70W in mine, and I am hoping to use the column shifter. I would like to run a bench up front, since I have my 6th on the way, I can use all the seating I can get. Otherwise, I think the floor shifters can be easier... If I had my druthers, I would run an electric shift tansfercase too, but they are too wide for our frame rails...
From what I understand the Lokar shifters are difficult to get installed and adjusted right and don't have a shift indicator on them. I used a B&M Truck Megashifter in mine that was easy to install, has a shift indicator, and works quite well.
mkaenel and i put a lokar floor mount shifter in his last week. it wasn't that bad (once i got the linkage arm pointing the right way), and it shifted nicely. there is no indicator, but there is a lighted one available that either goes in the boot retainer or remote mount.
The Lokar is definitely more attractive. I actually like that it doesn't have gates because most of my current column shift issues are dealing with the gates not matching between the tranny and the column.
