badmuttstang
redneck grease monkey
- Oct 25, 2009
- 2,807
Allen you are correct the variprime is not meant to go on fiberglass as such but we used it all the time on fiberglass that the gel coat had been sanded threw under recommendation of the manufacturer worked really well at sealing the fiberglass I know that's not the intended us but its what they recommend just to cut back on the different steps needed to get the cabs in for paint. It can be sprayed on to a decent thickness as well but don't think of it as a filler primer. I still use it at home when doing body and paint work one of the better etching primers out there.
