POR15 or Rust Bullet
69BroncoDad
Rutland
for a sandblaster frame and under the tub...would ya'll recomend POR15 or Rust Bullet???
I'd like to get the opinion of anyone who has used either..TY
ruckin69
My buddy swares by rust bullet, Ive used por 15 but I'm not completely sold on it. It it is not prepped perfectly, it does stick.
74creamsickle
Perkasie.PA
I used Por 15. I like the finish. And like any paint if the prep work is not done correct you may not be happy with your results. Good Luck!
Tuck
I did my frame with POR & used their chasis coat for topcoat. Turned out great. As was said, prep correctly per instructions (POR is a multi-step operation). POR will stick to rust better than bare metal, so don't be afraid of the flash rust after you spray the frame with water.
