Possibly the Perfect EB Master Cylinder
edge4
Gonzales, Texas
All in one unit. No more headaches. Will begin shipping this month. Both 1" and 1 1/8" bore, 3/16" inverted flare ports on the bottom. Remote reservoir avaiable. Not cheap, but very cool. I have ordered one for my Astro Hydroboost setup and will post tech article at that time.
Classic Performance MCPV-1:
After years of developing unique brake products, Classic Performance has developed their most innovated product yet. The all NEW MCPV-1 which combines the master cylinder, double adjustable proportioning valve, removable metering valve and stop light control all in one compact light weight unit, available for Disc/Drum or Disc/Disc applications. The MCPV-1 solves many problems associated with trying to do the same thing with four or five separate pieces being plumed together. The MCPV-1 is the master cylinder, proportioning valve, metering valve and stop light all in one package (Fig. 1). The unique shape allows it be located on the firewall, under dash or on the frame just about anywhere. It’s approximately the same size as the ever-popular Corvette master cylinder...only 260% lighter (Fig. 2).
The MCPV-1 has two circuits...front and rear. The front circuit of the MCPV-1 contains the metering valve, which is required on cars that have disc brakes on the front wheels and drum brakes on the rear wheels. The metering valve does not allow any pressure to the disc brakes until a threshold pressure has been reached. The threshold pressure is low compared to the maximum pressure in the braking system, so the drum brakes just barely engage before the disc brakes kick in. Having the rear brakes engage before the front brakes provides a lot more stability during braking. Applying the rear brakes first helps keep the car in a straight line.
The rear circuit of the MCPV-1 contains the adjustable proportioning valve and the maximum rear pressure adjustment. The adjustable proportioning valve controls the balance of pressure between the front and rear brakes. For example, if the adjustable proportioning valve was set to 70 percent and the brake pressure was 1000psi, the front brake would get 1000psi and the rear brakes would get 700psi, regardless of what type of brakes a car has. The Maximum Rear Pressure Adjustment controls the maximum rear pressure allowed to the rear brakes to help prevent rear wheel lock up. If the Max Rear Pressure Adjustment is set to 500psi and the adjustable valve set at 70 percent, the front brakes get 30 percent more until the rear reaches 500psi.
For more information on the MCPV-1 and other quality CPP products, contact 800-522-5004 ext. 114 (Jeff) www.classicperform.com
Dave St
Roanoke, VA
It is a great looking piece, that's for sure. If it actually does what it says it would be awesome. Any idea what kind of price these things will be? My instincts tell me that it would be more than I want to spend...
Dave St
Roanoke, VA
I looked at that site, but missed the price. It is less than I thought, actually pretty affordable if you needed to buy a prop valve anyway. I will add it to my want list. I wonder if the disc/drum model could be switched to the disc/disc model. If not, I will want to get rear discs first...
edge4
edge4
Gonzales, Texas
Metering valve in front is removable for Disc/Disc applications. This is whats great about this unit. One unit can adapt to different setups.
baby_blue
Laramie, WY
What do you guys think of the possibility of a mass buy on this unit? Especially since it is new and the company wants to get the word out. %)
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
Great. And I just ordered a stinking stone age master to replace the brand new one from Duff that was bad but exceeded the 3-year warranty. Grrrr.
YelloTx73
Katy/Galveston, TX
BoltBuster said:
Whats the cost on one for an EB?
Polished 189
Standard Finish 139
There is no bronco specific one. Its all the same stuff
The Corvette MC is a popular swap
Thanks for the link Edge, this is going at the top of the list of parts. This thing is awesome, hope it works as well as it sounds. I definitely need a new one anyways ;D
sbingham2
Cedar Park, TX
Has anyone gotten more information in this master cylinder and if it will bolt up to an EB? I'm getting ready to swap in a D44 w/discs onto a 70 and this MC seems like it would be perfect.
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
YEA the bronco account has a little coin. I am for a mass buy on this.
TOFIC
edge4
edge4
Gonzales, Texas
With old style corvette snout and same body size, it should be a perfect fit. I ordered mine last month. I believe Jeff told me I was around 300 in their confirmed orders. They've had thousands of info requests. First units should be shipping June 1st. I think a mass buy is out until the demand settles down a bit.
Although I will be using it with hydroboost, I will test fit it on my other EB's power booster for fit and clearance.
Edge
broncolove
The Bronco Ranch
S.E. Michigan
Southern rods also has a unit like this out just seen it in a Hot Rod Mag. Looks like a good swap into the bronco also. And a good price.
HERE IT IS
Oh yea it comes in a chrome version too ;D
4x4Alaska
Wasilla, Alaska
I e-mailed the company in July and they said they were not in production yet and still in testing. estimated ship date then was 90 days out.
67EB_in_619
San Diego
I just talked to them and they just had the first production run a couple weeks ago... there is about a 3 week delay in order/delivery.
They WILL do a discounted bulk buy, but the items need to be shipped to a single location... they offered to do $20 off per MC if there is at least 20 ordered. Doesnt matter if they are the polished or standard finish... btw, the standard are aluminum cast.. so it wont rust up like the iron cast ones from pepboyz. I think we might be able to talk them into including shipping to a single location... perhaps one of the vendors would care to do this?.. might even be able to negotiate a better discount?
I cant handle the logistics of this, otherwise I would take care of it... I am simply not that organized.
that said....
I am in for one standard finish!
who wants to spearhead this?
67EB_in_619
San Diego
Yeah.. I would be curious as to feedback on these too.. but who is gonna test it?
This is basically a cast aluminum corvette master cyl with a prop valve built in and the brake light switch built in... I know that with power brakes, my lights dont come on till half pedal due to the pressure needed to toggle the switch. The also works with disc/disc OR disc/drums.
Not a bad deal for $40ish over the cost of a new standard iron vette MC.
Take a look at the other products these guys make... looks to be some quality components.
