Power Brake Booster Problems?
67halfcab
Michigan
I have a completely brand new brake system, New SS hard lines, wheel cylinders in the back, new Calipers in the front, new Braided stainless lines from the frame to the axle and from the dana 44 to the calipers up front.<br><br>The problems I am having is I have to pump the brakes twice to get good stopping pressure.<br><br>I just bleed the brakes (twice) to remove all the air and I am still having this problem, so my conclusion is that it must be something with the Brake booster.<br><br>Any thoughts or suggestions would be greatly appreciated.
tonto
Try to keep bleeding them and have someone tap lightly on the caliper/wheel cyclinder your bleeding to get any trapped bubbles to move.<br>Did you bench bleed the master cyclinder before you installed it?<br>Good Luck, tonto.
75MIKE
NE Washington
With engine turned off pump up brakes and hold it. Turn motor on, pedal should go down easy. If it does the booster is fine.Booster would not effect having to pump the brakes.Sounds like you still have air in the lines or the master cyclinder has air in it.Or the master cyclinder is letting fluid around the piston, which means it's shot.
67halfcab
67halfcab
Michigan
[quote author=75MIKE link=board=5;threadid=9125;start=0#65271 date=1032133814]<br>With engine turned off pump up brakes and hold it. Turn motor on, pedal should go down easy. If it does the booster is fine.Booster would not effect having to pump the brakes.Sounds like you still have air in the lines or the master cyclinder has air in it.Or the master cyclinder is letting fluid around the piston, which means it's shot.<br>[/quote]<br><br>The Master Cylinder is Brand new (Not a Reman either).<br><br>I will test like you said to see what happens. I have a spare booster I could replace if it is indeed bad.<br><br>Thanks<br>
chuck
Ingram, Texas
Did you adjust the rear brakes? Are you using the chevy calipers? If yes is the bleeder at the top? Did you grind the sh*t out of the knuckles?
