Better yet, use the coil + wire to drive two relays, one for the HEI and another for the pump. You don't want either of those loads running thru the IGN switch. Put in some sort of safety switch in the fuel pump circuit. Either an oil pressure kill switch or a inertia switch, or both if you want to.
