- Jun 4, 2002
- 35,185
O.K. Had a chance to check voltage at various spots & this is what I came up with. The battery reads 12.5. Drops to 10.6 during cranking. These are the same readings I get from the stud on the back of my ignition switch (the acc stud I believe it's called). I get slightly lower readings on the I terminal of the solenoid. So wouldn't the ignition stud work the best for the single wire going to the HEI? That's how I have it wired now but its been difficult starting. However, since reducing my timing from 12 to 8 degrees yesterday, it's starting better.
The I post will read the same as the ignition switch and battery (minus some minimal connetion losses) IF there is no load. If you are measuring the wire without a load on it you cannot tell if there is still a ballast resistor in it or not. It takes a load for the ballast resistor to drop voltage.
Those battery voltages look slightly low. May want to have the battery and charging system checked out.
