Power Steering box popping
JC69 brnco
My power steering box is making a popping noise when you turn to the left and right.
Apogee
Tangent, OR
Yeah, that's probably not a good thing. Have you confirmed that the box is tight on the frame and that the frame isn't cracked where the box mounts, as that's a fairly common failure on these rigs when they get lifted with bigger tires and beat through the woods/rocks/desert/etc. Otherwise, if it's from inside the box, then it could be a multitude of things, none of them good.
JB Fab
If it's coming from the steering box that's not good! I had that problem (broken tooth on sector shaft), before I got back to the trailer (2 miles) the steering box seized.
Have someone turn the wheel back and forth while you are laying underneath, put your hands on all the moving parts to feel for anything that could be wrong.
nvrstuk
PNW
DO NOT drive it until you figure this out!! This is really important
