horhay25
Having a slight issue with my power steering..occasionally with motor running, in gear but at a stop it is very tough to turn the wheels (so tough that I think i've lost all power steering)..I'll drive a bit and the steering is fine, then i'll stop again in gear and turn the wheel and it's fine. This just happens occassionally and mostly when i'm in gear with brake pressed.
Here's what I'm working with...69 bronco, 33x13.5, International Scout box w/ what i think is a stock early bronco pump..
I'm gonna assume it's the pump, but just wanted to check your guys' opinions...
btw..i don't have any leaks and pump has fluid..
