73stallion
The XP4400E Features:
• Durable PowerMax 6.5 Hp, air cooled OHV engine
with low oil shutoff & electric start.
• Heavy duty steel frame with four point fully isolated motor
mounts for smooth and quiet operation.
• Wheel kit w front handle for easy transporting.
• Full power panel with engine shutoff switch, volt meter,
circuit breaker and power outlets.
• (2) Fully protected 120V outlets & (1) 120V/240V twist-lock outlet.
• 8 Hour run time.
• All steel 3.2 gal. fuel tank with ez-read gauge..
• Low oil shut-off protects engine.
• Super quiet muffler reduces engine noise.
• Idle control holds RPM at a constant level even under heavy
loads for fuel savings and noise reduction.
Specifications:
• Max AC Output: 4400 watts
• Rated AC Output: 3500 watts
• Current (120V/240VAC & 12VDC)
• (2) 120v 20A 3-prong outlets
(Standard Household plug).
• (1) 120v/240v 30A twist lock
(NEMA L14-30 3 Pole 4 Wire).
• Low oil shutoff.
• EPA & CARB approved engines.
• Super quiet exhaust w/ built-in spark arrestor.
• Electric Key & EZ-Pull Recoil start.
• 6.5 Hp air cooled OHV engine
• Fuel Tank Capacity: 3.2 gal
• Decibel: 69 dBA
• Run-Time [ @ 50% Maximum Output ]: 8.0 hrs
Includes:
• RV Switch for 30Amp 120v power to supply demanding RV needs.
• Extra large pneumatic tires.
• Flip-Up stow away Handles.
• Electric Starter & Battery.
• 8 Hour run time.
Specifications:
• Low oil shutoff.
• Decibel: 69 dBA
Includes:
