- Jun 4, 2002
- 35,066
Running injected 5.0 on the garage floor. Yes, runs and yes, sitting on casters on the garage floor. Out of a '95 mustang. Temp fuel system rigged off a gas can. No accessory drive (what little is left has bad bearings in the idlers). Has AODE (bad). Engine cranks over even, starts right up, runs smooth. Wiring has been trimmed back and labeled (battery, ground, switched ignition, start). Thermactor and EGR delete. Looks like it has never been opened up. Still has factory plug wires on it. Factory Mustang headers and cats still on it. Even have the gas pedal out of the car. No smoke on startup.
Needs rear main seal, timing cover (new damper but you can see where an old one walked back and kissed the cover leaving a small wear hole in it). Has a fuel pump but is too small to actually use, test run only. Little insulation nicked off at the TPS and idle air motor (think it was a mouse, only damage that can be found).
I know that a non-runner sitting on the garage floor is basically a core, ~$200. But a running engine is worth more, how much more?
