Printed Wire ?
DEEPWOODS
Anyone know where I can get the automotive Printed wire, like fuel pump ,radio ,Tps ect. From? Like is in most of the harness Thanks Keith
brianstrange
I'm guessing an aftermarket harness...... Not that I know of, but you can use color coding and get the same result
graniteguy
Kempner, TX
ditto. I would imagine a low buck kit like ezwiring (and clipping the wires off) would be easier and cheaper than finding rolls of each one.
Keep in mind that large companies go through a LOT of wire building the harnesses. They just special order the wire in mega spools with the prining of there choice.
If you find any large wire manufacturer who is willing to do an order for you I am sure they will print anything you want on it. Keep in mind you will probably have to buy it in 100,000 foot spools at a time. Not sure what you will do with the other 99,990 feet of wire with your custom print after you use the 10 feet you want?
512cadillac
What do you really need? I have some left over wire with the print like you want. If it is long enough to meet your needs you can have it for shipping. John
brianstrange
Beyond primary color, I have made a jig that you can pull wire thru, and add a secondary color to the wire with a colored sharpie set.
DEEPWOODS
DEEPWOODS
I have found that Centech sell a small kit AW-1
