- Nov 11, 2007
- 8,225
Yeah, but did they fit edelbrock head? I'd call edelbrock tell them you have studs pulled. From damage to rocker looks like rocker pulled the stud out, and not that the stud was put in wrong. I would see what edelbrock can do for you, and then use edelbrock rockers on their heads.
Yes, you need an honest to goodness pushrod length checker. I forget which one is closest to a stock 302/5.0 but call summit they can set you up. BTW when I went edelbrock heads, every stock pushrod was wrong.
If I were you, good job so far, but get rockers, pushrods, made for your heads.
That pulled out stud, going to need a machine shop if edelbrock doesnt send you a new one. Seeing damage on rocker, they will probably decline to help. I would wager the rest of the studs have been pulled to some extent. Find a good machine shop and they can help.
Personally, those little aluminum shavings shouldn't do much if any damage to cam so i would leave it. You can get a flashlight and slowly rotate motor around to get eyes on the cam surface.
