WARDOG
I have had gauge problems for the past year.
Sometimes they work, sometimes not. Will work for a week, a month, and then not work.
I have replaced the gauge cluster regulator 3 times all with the same problems.
I have replaced the sending units (temp and oil) 3 times thinking I had a bad part but problems still persist.
I have cleaned all contacts.
Oil pressure gauge was reading half of what the mechanical gauge says.
I use teflon tape for sealant on the oil gauge and RTV sealant on the temp sensor.
Can someone explain how the gauges work. From the sending unit to the cluster, black wires going to every gauge and what the regulator actually does?
Does the sending unit measure ohm resistance and send that to the gauge?
Just frustrated.
I have considerable electronics (subpanels, relays, switch panels) to install but I need to get rid of the bugs first.
Just frustrated.
