[quote author=jee
ster link=board=5;threadid=21760;start=0#msg167508 date=1062716386]
you will want to know the firing order on the cap, find #1 on the cap, turn the Dist so that the vacuum advance is pointing toward the front (fitting it so that you can turn the Dist both ways to time), point the rotor towards # 1 post on cap. (fit cap on dist, then mark dist housing with a mark inline with #1 on the cap) drop in place, snug down with holdown. (might have to slightly jiggle crank a little to mesh the gears).
[/quote]
Jeeptser has got he key here...
Drop the dist in with the rotor pointing toward tower #1 on the cap and the vacuum advance nipple pointing straight at the radiator. This all should be done with the engine on #1 comppression stroke. You may have to bump the engine over a little to get the oil pump drive to mesh so that the dist drops in all the way, then crank it around till you are on the timing mark #1 compression, then check to see if your dist rotor is pointing at tower #1. If not you will either have to adjust the dist timing if its close or remove and repeat the dist installation process a tooth or two in the direction you want it.
~BH
