With that attention to detail, how are you going to finish the positive battery cable at the clamp?
I've ran into an issue. Got the bronc wired and only thing not working is the passenger side brake light and flasher light here on the same side. The signal on the passenger side works fine also the driving light here works as well. After hrs of troubleshooting I traced it up to the turn signal wiring mechanism on the steering column. I'm guessing this is the problem. good voltage on everything up here but the dark green Centech wire at the signal which feeds the rear passenger side light has no voltage. My Column is a 1974 with the hazard switch in the column. Where might I find a new harness for the column? What do you all think?
I've had issues a couple times with the cancel cam in the column, I think that's pretty common. My bet is that if you pull the steering wheel and just put pressure on that cam, you'll probably get the lights to come on. I believe I got the last my last one at Napa. They're a PIA to get to work right but it might be easier than a harness since you probably pinned yours for the centech. BTW the harness is ~$50 at Wild Horses WH steering column parts
Just my 2 cents.
-Steve
I have to admit, I do everything in a hurry. I didn't have time to look for connectors so my wires are all spliced a few inches above the connector. Soldered and heat shrinked of course. There's got to be someone local that carries them, as I remember they seemed pretty generic. It looks like the connector comes in a kit of it's own for ~$30 from painless. Also, Ryan has a bunch of high end connectors at RJminjectiontech.com If he has them, they are a few cents each.Thanks Steve I will call Napa and see what they have. Now would be the time to change it out. Where could I get more of those pins?
fixing to install a centech in my 72. i guess i made a good call when i decided to replace the turn signal switch and harness. what alternator are you running? i am running a powermaster 70/100 and was told i could wire it up straight to fuse block and shouldnt have any issues just wondering if you knew anything about the high output alternators.
