Project for an Iowa winter, '77 Ranger
R
renrag
Eastern Iowa
Nice work!
Did you shoot it? If so how did that go? How many cans did you need?
Thanks, Doug
I did shoot it. HVLP gun with a 1.7 tip and sprayed at about 60psi(after some trial and error) to get it as smooth as possible. In the end, it looks like an extreme case of orange peel(pun not intended) vs. the usual look of bedliner. I was coached by someone who has used it often on the inside of custom motorcycle fenders. I believe he achieves a smoother result because of the size of the project. I also sprayed it wearing my full, fresh air hood since it is an isocyinate(sp?) hardener. I used four cans and am 1000%(hyperbole not a typo) glad I had a primer that was close to the right color. Tinting with base coat did not provide very good coverage. Film build was good, but color coverage was not. I covered the floor you see, plus the outside of the kick panels(forward to the grill, but not inside the inner fenders), and the back side of the front fenders with the four bottles.(4.4 liters of mixed product including the tint)
p.s. I like your moto about the number of Fords vs. available time.
kip60
You do amazing work. Makes the rest of us that take 3-6 years to fix things up look like pikers! Good luck with the rest of the project.
R
renrag
Eastern Iowa
I have two tricks up my sleeve. 1) I am a corn farmer who has less to do in the winter months. 2) My father is "all in" on this. He is in the shop 6.5 days a week. He has done most of the frame, all of the engine/trans/axles, repainted a lot of the little parts that are ready for reinstall, as well as some of the bodywork. I have done the tub assembly, roll bar fab, and some of the painting. Now that I type it out, I am feeling like a slacker..
904Bronco
San Martin, CA
Thanks for sharing... I want to shoot the 67 tub top side with RL and not sure what to do on the bottom side yet?
R
renrag
Eastern Iowa
Ever forward.
R
renrag
Eastern Iowa
Despite our best efforts, I have to admit defeat and get the JK ready for Moab Safari. I had hoped to take the Bronco, but a couple small delays added up. If I had the paint that was delayed, and if I were not traveling with the family before Safari, it might have happened. Instead, it will sit like this for a while.
sprdv1
REBEL
All in due time I suppose.. Hope y'all have a good time at the safari..
R
renrag
Eastern Iowa
Thank you. We have made nice progress, and making the first real drive on trail, might not have been the best idea. Almost everything is restored. Mostly assembly left. I am pleased with the product so far.
Taking a proven rig to Safari does lower the stress level.
sprdv1
REBEL
Please tell me that is a joke, not a comment on the quality of Raptor? I don't plan on crossing the Rubicon, but see it bopping around CO mountains or Moab trails like Hell's or White Rim. Unless someone makes a stupid offer on it.
I meant just looks to good to get scratched up. Very impressed.
But I don't blame ya for hitting some trails Fun stuff
R
renrag
Eastern Iowa
Worked a bit more.
R
renrag
Eastern Iowa
I guess it is time for some updates.
R
renrag
Eastern Iowa
Upon assembly, my ignorance of Broncos came to light. See, I unknowingly fitted the wrong door. The wrong door was pulled when my order was filled, and I just flat didn't notice. Dad and I are still scratching our heads on that one. Anyway, with over 10hrs of work already into the wrong door, we punted, and just put more work into it. The old door provided the pieces we needed to make it all work. So, my driver's door is now a test. Anyone who notices it in person, will truly be a Bronco expert.
R
renrag
Eastern Iowa
Finished. Well, road tested anyway. The underside shots were taken at the muffler shop, and the rear driveshaft was also obviously missing at the time. I drove it for the first time yesterday, and put 30 miles on it. Mostly short trips, then back to the shop to tweak things. Another few trips like that, and it will be "done".
p.s. my phone camera does funny things with the color of the paint sometimes. The engine shots above, are some of those times.
R
renrag
Eastern Iowa
Ha. Forgot the underside shots.
904Bronco
San Martin, CA
Absolutely Beautiful!
I am a little Orange biased too...
Missing the flex vent hose from the CC canister to the air cleaner? Need a part number?
bronkenn
Bronco Guy
Southeast Ohio
That came out beautiful. You and your father did an awesome job. You guys must have a cape on under your shirt. Ken
