EagertoLearn
I know the top two holes are where the brake lines run up to the master cylinder. Is the opening in the back of the proportioning valve where the lines runs to the rear brake lines block the rear end? There also is a port in the front is this where the line for the front brakes start? Also where does it go from that port to where? The final port is towards the front of the proportioning valve but on the bottom side. My original one seems like it has a plug in it, is that correct? The next picture is the rubber brake line which has a block on the end. Where does this mount and how does the line from the proportioning valve attach at?
