EarlyElway
I just installed a new disc brake conversion kit that I ordered from JBG.
I ordered the one that came with the proportioning valve and this is the last thing I need to do before bleeding the lines to see how the new brakes operate.
I understand the location for the valve is on the engine frame below the steering column which is a paint to get to. It also appears that there is already some sort of OEM valve there that is different than the one they sent me.
My question is two fold:
1.)Can I just hook the brakes back up without putting the new proportioning valve and if so will there be a significant lack of performance?
2.)If I were to install the new proportioning valve up closer to the master cylinder with a drop bracket can I leave the hardware(valve) that's attached to the frame or will this also affect the performance?
I am trying to avoid having to work in that tight space and fear the I may damage the brake lines in trying to remove it and I don't want to run lines.
Thanks!
Thanks!
