A proportioning valve is not a requirement for hydroboost or disk brakes. Ford never used one on vehicles designed with those systems.
Bold statement. Totally factual, but you are going to confuse the huddled masses.
The "thing" that connects to the master cylinder in modern disc brake automobiles (after about 1971...) should be called a combination valve. The combination valve performs up to 4 basic functions when used with disc/drum applications.
1. It CAN provide front to rear brake bias, (proportioning valve or metering valve)
2. It CAN provide delayed application to the front hydraulic circuit. (delay valve)
3. It provides a hydraulic failure warning circuit shuttle valve.
4. It provides a distribution junction point for convenient plumbing.
Unfortunately, the combination valve has been named the "proportioning valve" whether it provides any proportioning or not. This mis-nomer causes great confusion and has resulted in the sale of countless un-needed brake hydraulic components.
A properly sized and engineered disc/disc system does not require metering, biasing, or delay. So the 5 port "proportioning valve" is just acting like an expensive h-block.
An improperly sized disc/disc system needs metering. This can be done with a 5 port proportioning valve, or with a discrete valve in the rear line.
All disc/drum combination systems need a delay valve to prevent front wheel lockup on panic application.
@Big Slim I hope that helps.
