Proud new Bronco owner..Need advice!
Cody51
South Carolina
Hey guys! I’m new here and currently in the process of having my mother’s 71 Bronco shipped from Texas to me here in South Carolina. She’s had it for about 11 years and has done a few things to it but nothing major. It did have what I believe is the James Duff 2.5 suspension lift (correct me if I'm wrong) already on it when she bought it and it currently runs. I have no experience working on Bronco’s and honestly pretty limited skills when it comes to working on cars.
This is going to be a slow project that will probably take me more than a few years to complete and I want to do most things on my own but I’m not sure where to start!
What do you guys think would be good starting point?
What are some of the mistakes you’ve made along the way that I should avoid?
What would you do differently if you started over?
I would really appreciate any suggestions or pointers
Pictures
Thanks!
Cody
stout22
Athens, AL
Congratulations!
I would make sure the Bronco is safe to operate - brakes, steering, suspension..
Broncos are actually fairly simple to work on.
Bajabrewer
Cody, Welcome - you've come to the right place. Looks like a great start for a project Bronco. I would make sure it runs good & the brakes & steering are OK then drive it some before deciding on your next move. If you can try to tackle 1 thing at a time you will continue to enjoy driving it & still make progress while learning what you like and what direction to go next. Be careful of the the temptation to tear it all apart & fix it all at once - this works for some experienced restorers but often people get overwhelmed & lose interest. The search function on here is your friend & read up on the next project you intend to tackle. Most of all enjoy the Bronco!
David A
svastano
Pulaski, PA
Welcome! Lots of folks around this board that are extremely knowledgeable, and very helpful. Also we like pictures! LOL
SouthPaw74
South Florida
Good luck with the build. Looks like a great starting point! Check out Dennis Carpenter and National Parts Depot for parts with decent shipping to the Southeast. Also Classic Ford Parts out of DE!
bigjhoov
nobody
Get it running and drive it for a while if possible. Jumping in to a long term rebuild can be a daunting task. Create some memories in it first to help pull you through the doldrums of a complete rebuild.
BronCowie
Old Timer
Vancouver, WA
Welcome Cody and please become a "Contributor" which amoung other things makes it easy to post pictures, which we are all going to want to see. :cool:
ared77
Welcome! Great advice above, and I love the look of UN-cut rear fenders.🙂
fluffybunny
Check over the wiring real good. You don't want your new toy going up in flames. When I started on mine, I went through and made a list of all of the parts I needed and ordered most of them. Now, 10 months later as I'm wrapping it up, I'm having to dig through my big box of stuff looking for the part I'm looking for. I did a pretty good job of writing on the bags what the parts were for, but would have been better off sub-categorizing them even more, maybe breaking them in to front end, interior, etc.
Rustytruck
I suggest you get it running properly and drive it before you do any long term projects. I also encourage you to take it to a couple of events before you jump into long term projects. allot of projects get torn apart and lost interest. going to events seems to change peoples minds as soon as they see what they find out what they truly want fixing up these rigs become very expensive let alone doing it over when you change directions.
BronCowie
Old Timer
Vancouver, WA
Planning on it. Is the picture link working?
If this is what you're asking about... Yes!
kat
Bristol
Like everyone said, make sure everything is safe. I can confirm you have the JD 2 1/2 lift on the front. Its the same hoop system that I am running. Start and focus on one thing at a time, like upgrade brakes or new suspension. Things on these Broncos tend to 'snowball' if your not careful. Like 'Since I have the tire off I might as well do brakes, since Im doing brakes I might as well replace axle bushings.
Look around on here at other peoples Broncos, and you will find that none are exactly the same. Everyone here has an idea of what they want to end up with. I didn't see a top in the pics and they can get expensive. BUT if you only want to drive it on nice days this might not be an issue.
When talking about tire size on a uncut or LUBR there are body lifts that can help out. And there is a good chance the original body bushings are worn out so if you have to replace them, make sure you only do it once since you want to keep the original look.
The search engine on here can be hit or miss but its a great way to kill 5 hours doing research. This website IMO is the only website you need. ALOT of knowledgeable people on here. Good luck
Cody51
Cody51
South Carolina
Thanks for confirming the suspension for me! It does have the top but it’s in pretty rough shape.
  • Like
Reactions: kat
Cody51
Cody51
South Carolina
Appreciate everyone's advice! I pretty sure my first project is going to be a brake conversion.
Anyone have experience with the Tom's offroad kit?
Would you guys recommend that I do both front and rear at the same time?
sprdv1
REBEL
Congrats and welcome aboard Cody!! You found the right spot for sure..
Waldo
I put in the power conversion kit from Tom's in 1997. Had to replace it in 2008. Then replaced again in 2018 when I put in rear disk kit. Of all the changes I have ever done on the truck, the power brake conversion was the biggest improvement in performance.
