PTO Seal Removal?
mavman427
Nipomo, CA
Anybody have an idea on how to remove the PTO seal while the transfer case is still in my Bronco? The shifting rod is in the way, so it's not easy to get something behind the seal and yank it out. I've tried prying it out, hitting it with punches, etc. and I've accomplished is mangling it so far. I really don't want to have to pull the whole transfer case to replace that one seal.
JSBX
Pto
When I changed the seal in mine I just pried it out with a screw driver. If it want pry out you may have to chisel it out. Be careful not to damage the the mating surface where the seal mates to the pto. A smal sharp chisel works the best You could just remove the PTO from the transfer case. A couple of the bolts are a little hard to get to but I have removed several. Working on it on the bench is much easier.
mavman427
mavman427
Nipomo, CA
I took your suggestion and removed the whole PTO from the vehicle. That made it about 1000 times easier to get the seal out.
