Pull-A-Part Finds
BoureeOne
Madisonville, La
Went to the pull-a-part on Friday just to look around. I came across a couple of things that I thought were interesting. First one I found on a couple of different year Explorers, these were not on every expolorer. I probably looked at 20 explorers and only found 3 that had these. They are plunger switches mounted in the engine bay for turning on the engine compartment lights when the hood was raised. Very simple design with a bracket that would mount easily on the inner fender. I picked up all 3 of the ones that I found. I will keep one and figured some of you guys might be interested. The shiny bracket in the pic is where I wanted to see how it cleaned up on the wire wheel. They will clean up really nice. I will sell the other 2. $20 shipped.
I thought about the second thing as I was walking past the Chevy section. I owned a 99 Z-71 years ago. There was a work light mounted in the engine compartment on the fender well. I am sure some of you have seen these before. The light is mounted in a bracket. You release the light and it unwinds on a 15 foot extention cord. You then wind it back in on the build in winder. There is an on/off switch on the mounting bracket. The light also has a magnet mounted to the back so you can stick it where ever you need light with out having to hold it. So I started looking around and found one. I saw actually a couple, but only one in good shape. I found them on trucks and suburbans. The last pic is after I cleaned it up a little.
When I got everything back to the shop I tested them. The switch and the light work perfect. Both will be used .
Scott
BoureeOne
BoureeOne
Madisonville, La
Another note if anyone would be interested. There was a late 60's or early 70's Thunderbird with a 460, with PS and A/C. It looks complete.
Just an FYI
