WARDOG
A couple of weeks ago the right front brake locked up tighter than a tick's ass.
It was driving fine but when I depressed the brake the right disk brake locked up.
I put air in the line and limped it home in the snow.
I bought rebuilt brake calipers and installed them thinking it was a bad piston.
I got everything put back together today with fresh pads. I drove about a hundred feet and depressed the brake and the same thing happened.
I took the wheel off and tapped on it with a mallet in case it was binding up on the guide rods. Something is not allowing the pressure to neutralize after letting off the pedal. All other corners work fine.
It has a D44 front with disks. It happens with or without the vacuum hooked up to the power assist.
All air has been bled properly and nothing unusual happened prior to this problem starting.
Suggestions?
Suggestions?
