Question on Coyote conversion and firewall
Lt1Burb
Which holes are not needed when doing a coyote conversion, I would rather weld them up now then plate over them later, thx.
Jamie Chriss
Q
Vintage Air
AT or Manual
1 is this hole being used to run the Ford Controller
2 i am not sure what was here before, not needed
3 Clutch hole? not needed if running AT
4 where are you running the hot water input and exit for the heater. Vintage will be where the square is
5 if running vintage good place for the sensor wire.
Lastly a lot depends oh where you are running you AC lines, various factory wiring. I have posted a few pictures on my build, I am also on Instagram 360 Bronco.
L
Lt1Burb
Q
Vintage Air
AT or Manual
Thx for the response, it is an auto and yes I will be installing vintage air.
EPB72
Pleasant Hill, CA
Haven' t used but read through install instructions the American auto wire bronco updated wiring harness kit appears they dont run the engine wires through the center of the firewall but out the right side so may not need center holes.. Just going to have to mock everything up before paint.
Jamie Chriss
I am 99 percent done with my new Coyote Bronco. I ran everything out the passenger side air vent. Holes used two passenger side, left of center. Single hole center for temp wire. Drivers side used just one large hole. Used all Dakota Dig products.... your firewall seams to have a lot of holes. Feel free to ask questions on my Instagram I check that often this site dosn't have many Coyote peeps, they seem to have moved elsewhere?? Facebook has a large EB Bronco Coyote page.
