Hi. I just replaced my rear tank due to contamination problems. I'm wondering if I need to replace the side tank. Been doing a little reading on the subject and I saw a note saying the side tank is a factory poly tank. Is this correct? If so, should I worry about contamination from the poly tank? The contamination I have is a very fine black powder, small enough to get through the filters. I saw some evidence of this in the pickup fuel sock on the main tank. However, not sure where it could come from. If the side tank is poly, is it possible I'm getting fine particles coming off the tank? Maybe my problem is the Aux tank and not the main tank. I was thinking if the side tank is poly, I don't need to worry about rust or metal corrosion, but maybe I have plastic that starting to break down. Anyone seen this before?
Thanks.
Thanks.
