quick engine question?????
66bronc
Jourdanton
I am going over a 302 from an 86 thunderbird. It has a stock roller cam and lifter set. Anyone familiar with these? I am wondering if i can go to a flat tapit cam and lifter set or does it need to stay roller. I am wanting to do some mild upgrade to it nothing too big, i was wanting to put the edelbrock power package, cam and lifters, into it. Can I do this or does it need to stay roller setup? Do I have to change any other parts if i don't use the roller cam and rockers? I want to replace the cam and lifters but the roller setups are expensive, aren't they? Am I just better off just leaving it alone?
thanks
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
You can change back to regular cam and lifers BUT not many people would. Suggestion - Call Crower cams and ask about having your stock cam " tuned up " You send it to them and they will re-grind it and send it back for pretty cheap. Use your old roller lifters and buy some new springs. I had crower re-grind a couple of cams for me and for a extra few bucks they can get them back to you in three days. It doesn't cost much at all even for the FAST SERVICE. Crower cams are great. They really know what they are doing. Crower was maybe the first company to ever offer 5.0 roller cams, back in the day they ground cams for California Hi-Way patrol and that was a pretty good cam on MY core.
U
Unregistered
Guest
YES! you can go either way you want, I went with this
87' Roller block
83' crank (dads wrecked Crwon Vic) and stock rods ARP'ed everything
97' "p" heads with stainless valves enlarged the ex to a 1.60
Weiand shealth intake
Comp cams Extereme Energy 262H flat tap
Melling HV oil pump
Milodon HV water pump
I run a C4 trans and thats the biggets you can run w/o a stall. As soon as I fgure out what headers to run and carb and I put the thing back in ill tell ya how it runs...i already know that but Ill wait. BTW the biggest differnce is push rod lenght and the roller block has two threaded holes in the valley to bolt down the bones and x's for the roller lifters. Dont forget that 86" 302 is a 50oz inbalance motor and you must change your flexplate or flywheel and run a 50 oz balancer. Good luck!
