Engine Break-In, quick question!
76BroncoSport
McKinney, Texas
Hey guys, refresh my memory. Is it best to use something like Castrol GTX 10W-40 for engine break-in? Also, would it hurt to add some of that Marvel Mystery Oil as well or would that provide too much slipperyness(is that a word) for break-in?
Use a conventional oil (the castrol is fine) for the break in. Prime the oil pump before starting it. Run the engine at 2000 RPM for 20 minutes. Change the oil and filter. Start driving it. Avoid long constant speed driving and full throttle for a while. 100 to 5000 miles depending on who's opinion you get. Best one I have heard is to break it in like you are going to drive it.
As for the Marvel's oil, I have never heard of anyone using it for break in before. Not to say it's bad. I do see some benifits that might make it good for break in. Extra detergents to flush out the machining particle etc.
GRIZZLY
Lakewood, CA
Definitely DON'T use any synthetics or friction reducers until it's broken in. Rings have to seat, valve guides.etc. I'm going 5k on mine until I switch to blended synthetic.
rflud
Modesto, CA
I've always been told to use a Non-detergent Oil to break in the engine for 500 miles. Then switch to a regular oil. I would still be easy on the motor for another 1000 miles or so.
I have this on what I think is good authority. But everybody has their opinion.
sicaz66
san diego
straight 30wt.run it for 20 mins at 2000 rpm`s , change it, then drive it like you stole it. :p
[quote author=rflud link=board=5;threadid=15269;start=0#msg115745 date=1047854684]
[/quote]
You need detergent oil for the break in. What the detergent does is keep the dirt in suspension so the oil filter can capture it. The only non-detergent oil you can get (If you can even find it) is a SA rated oil. Only suitable for lightly loaded old school (1930’s) engines and oiling door hinges.
If you break in using non-detergent, then switch to detergent, the dirt that settled to the bottom of the pan and valley will get circulated after you change the break in oil to regular oil.
Just run a conventional oil similar to the oil that will be run on the normal oil changes.
rflud
Modesto, CA
Well like I said everybody has their way of doing it. I've done it this way for a few engines and the guy that told me this was the way to go has several hundred engine to his credit.
But I bet it's like the gasoline arguement - everybody has an opinion but the bottom line is the engine will run on any unleaded fuel you through in it.
So go for it - 10w-40 sounds great. Hope the motor runs strong and when you're wheelin' keep the rubber side down ;)
[quote author=rflud link=board=5;threadid=15269;start=0#msg116012 date=1047941268]
[/quote]
Your right about everyone having there own way of doing it. I knew a shop that there polocy was to break in an engine for 20 minutes with no water. They said the extra heat broke the rings in faster. Tht shop never touched a vehicle I owned. nuf said.
rflud
Modesto, CA
[quote author=Broncobowsher link=board=5;threadid=15269;start=0#msg116029 date=1047943832]
They said the extra heat broke the rings in faster. [/quote]
Yeah, nothing like making your engine have 50,000 miles of wear in 20 minutes ;D
sicaz66
san diego
[quote author=Broncobowsher link=board=5;threadid=15269;start=0#msg115888 date=1047914193]
[/quote]
[/quote]
oops!
