csjr
I'm fixing my stock fuel gauge once and for all. I don't expect digital accuracy, but I'd like to at least get stock performance. Since I've bought the truck it has never worked properly--always a lot lower than reality and reads empty when it should say 3/4 tank.
Anyway, I checked IVR on back of gauge cluster--pulsing power per test light and voltmeter. I checked wiring all the way back to tank--pulsing brightly with test light. I grounded power back by tank and gauge pegs full as expected; therefore, I conclude good IVR and good gauge. I take off the ground and test resistance with ohm-meter....it's jumping all over on my lowest scale (200) so I'm assuming I'm getting pulsed power through the sender at the ground. Now, I could not find a battery to chassis ground on my truck. PO has rewired (what an F-ing mess) and I see ground straps from chassis to body and engine. Is this critical for gauge function? I'm thinking I can add a strap from battery to same place on front fender well where body to chassis ground terminates. I'm thinking this gets me to chassis. There's a massive ground cable from battery to engine. Any info would be greatly appreciated. Getting the fuel gauge to work would double my functional gauge count.....![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
