rockerZ71
hey yall
i swapped in hydroboost and a saginaw pump out of a 70s lincoln to my bronco around Christmas time. Its got a '93 mustang motor so I had to hack up my bracket a bit to make this pump fit. Well its been eating serpentine belts because its off a bit so I ordered the "lars" bracket for WH hoping that would fix it. I have a couple problems
So, does anyone have a part number for auto zone or advance preferably of a pump that should work better? Would like to be able to re use my fittings since I really have no other option - have to get this back together to get to work tomorrow and my ghetto bracket isnt much of an option, probably need 2 serpentine belts to get to work.
Thinking changing pumps sounds like the quickest solution but not sure if any of them address the problem of that part that sticks out past the bracket - maybe it would though. sounds like other people have done this before
i have no a/c so my pump sits where the AC compressor would have been
any advice etc appreciated, maybe i can find someone to give me a ride to the store before I start cutting up this fancy new bracket I got
- my pump is the type that is rotated/clocked differently so it doesnt fit in the bracket
- part of my problem is that i need the pulley to come up to just about 1/4" from the face of the bracket to line up, and the part that protrudes from the pump around the shaft makes that difficult (its too long so I need big spacers)
- WH only sent me 3 of 4 spacers that should have been in the bag. Can use washers or something but that sucks
