I have seen a couple of different "suggested" values for the torque on the nut. But, what you really want is the proper preload on the bearing. This can be measured by spinning the pinion with an in-lb torque wrench and carefully watching to see what value of torque it takes to spin it. With a crush sleeve, I would check this value several times while torquing the nut. Better yet, ditch that crush sleeve and go with a solid spacer setup.
For new bearings, the value should be 13-15 in-lbs
for used bearings, the value should be 6-7 in-lbs.
http://www.ringpinion.com/Content/HowTo/TechnicalInstructions/Yukon_Installation_Kit.pdf
