- Jun 5, 2007
- 1,255
I’m mocking up my frame/suspension , and I’m to the part of installing the c bushings. I have one arm attached to the axle. All seemed to be going fine. But when I tightened the c bushing bolts all the way down, I noticed one part of the bushing is slightly off.
I believe these are the polyurethane type. But Idk for sure. I bought them local as a sacrificial bushing for mock up. I believe they are for stock suspension as I don’t see any numbers on them.
I noticed when the 2 pieces of steel joined together on the radius arms that they were slightly off. And that got me to looking at the actual bushing. 3 of the 4 sides look perfect. But the top rear looks a little off.
Wondering if this enough to mess the coil spring cup location? And should it be redone, even if the spring cup location would be fine. I did slightly loosen them, then put a big channel lock on to try and even it out. Changed nothing.
But if it’s fine for mocking up I’m not going to touch it. Just wondering for future reference would this be considered acceptable to run with or would mess with the caster?
Last thing is I bought this lift from another member in 2009 It is an unused 3.5in Duff lift. I think he had it a couple years before he sold it to me, so it’s old.
The c bushings are 6 1/4 and I thought for a 3.5in lift you need 4 degree c bushings? Wondering if this kit was packaged wrong. Or is that the correct degree for up front. 6 1/4 would make sense to me as the rear shims are 6 degrees. I just saw an old wild horses video where he said 4 degrees for a 3.5 lift.
But I’m getting kinda close to putting this back on the road and trying to get it right.
First 3 pics are the issues. 4th and 5th is what the rest looks like. Rest are the difference of the bushings.
