Hey All,
Is there a diagram out there showing where the factory radius arm mounts are located on the frame? I basically need to locate the cross section for the stock hole on the outside of the frame both passenger and driver side. The frame has had them welded up and need find the factory mounting position centerline of that threaded hole....Thanks
