I just torque the radius arm nuts to sufficiently compress/preload the urethane bushings and then install the cotter pin through the castellated nut. I wouldn't aim for 90 ft-lb myself since that's not really the purpose of that nut anyway. It isn't about stretching the "bolt" a certain amount, it's about compressing the bushings and securely locating the front axle. Considering the factory bushings were rubber with a significantly lower durometer than the urethane replacements, I really do question the merit of the 90 ft-lb torque spec.
