Stripped threads in radius arm
dbbronco
was putting in new c bushings with a new lift kit and learned that two of the threaded holes in my radius arm on the drivers side are stripped. what would be your advice? take it to a machine shop for repair? will it be right if I go that route? or replace/upgrade with after market? '72 bronco with 2.5" lift. Help!
B RON CO
Statesville, NC
Hi, I have used Helicoil kits and they always worked perfectly for me.
You need the complete kit with the drill bit, tap, and inserts. Good luck
71massbronco
Or you could drill them out and stick grade 8 nut and bolt with a split washer? Easy cheap fix.
D
dbbronco
should have mentioned, tried that, not a big enough flat spot on the backside for a nut and washer
Well being classic Bronco site, no one has suggested putting long arms on yet?
No room for a nut? I would be doing a little grinder/carbide burr action to make room. At least to get it back together for now so it can leave the garage. Keep an eye out for another arm if that bothers you.
I know the helicoils are good. But I save them for when they are needed, as in about the only choice.
Jamie Chriss
I did that exact thing to my brand new JD arms. I took mine to a good metal shop and had the treads cleaned up. If no cleanable replace for sure. I just gave mine away last week...God luck
sykanr0ng
Drill and tap for a larger size?
  • Tap_Drill_Chart.pdf
Jamie Chriss
2nd that, drill and tap! But before that see if you can salvage the original bolt thread. Without seeing the treads I would try and get them cleaned up first. Those are some serious threads... Good luck
Glass Pony
Sussex County Delaware
The 2 stripped holes for me would be enough for me to go to Duff's T-Rex arms.
Sorry, I'm just looking for an excuse to go to T-Rex arms, they are sweet!;D
wepuckett
If you have a lift on why would you go trex arms and not long arms so you get that extra articulation, never know when you need it
Sent from my SM-P580 using Tapatalk
Glass Pony
While I do agree with you, the original poster and I have 2-1/2" lifts.
This is from the description of the long arms on Duff's site,
"Requires at least a 3” suspension lift for best off road performance."
bronconut73
A few fellers have done the Duff Long arms with 2.5" lifts so it works but just must not be the best iteration.
D
dbbronco
Just following up guys, I did go with the helicoils, had them professionally installed by a local machine shop, all 8 holes. Then cleaned up the arms and the caps, painted, and installed them, torqued to 100 lbs and everything worked great. Appreciate all the good advice!
AZ73
Thanks for reporting back! This will surely help others in the future!
