Kyle.malone
Stone Crusher steering for D44 and set up for Ram Assist
PSC Pump with V belt (need bracket from WH)
PSC Ram
Hydro lines from Steering box to ram with quick disconnects. These allow you to unhook the ram in case of emergency like you break the ram or something. They self seal and are male/female so you can't get them reversed.
Borgeson Steering Box ported by PSC. 1 ear is broke off, but there are still three left. two will bolt directly into the bronco frame and the third needs to be drilled. I spoke to PSC and if the broken mounting hole is a big deal to you. PSC has a new box casting that they can swap all the internals and port it for $250.
Wanting to sell as a package and will ship on your dime.
All parts are a year old except for the steering box. it is 2 years old. And yes the pitman arm will stay as it works with the Stonecrusher steering setup. I have the hardware in a plastic container for the steering (bolts and spacers that are used)
I pulled this since I am upgrading to the Dana 60 and am going to full hydro.
PSC Ram
