Assuming yours is an old style with a separate control box, (i.e. RE8000, RE10000 etc.) and not the newer style with the integrated solenoids, take the square plastic cover off the part where the remote would plug in and you should have 2 solenoids looking at you. Same exact style as the one used with Ford starters. One controls forward and one for reverse. Hook the power cables to a battery and jump the two large lugs on either side of one of the solenoids. You can use 2 large insulated screwdrivers or some heavy gauge wire like old battery cable to jump the two sides. The drum should then rotate one direction or the other. Do the same thing on the other solenoid and it should rotate the opposite direction from the first try. I would have some slack in the cable in case you hit the "in" direction and it locks up on the hook and tries to roatate itself right off your table....
I'm sure you can jump the pins where the remote would plug in to for the same result as I'm sure one pin is power, and one pin to each solenoid, with the last pin going to ground, but can't say with enough certainty to lead you down that path.
