https://www.jegs.com/i/Powermaster/...riteo&utm_medium=cpc&utm_campaign=retargeting.
Why would you want to do this.
That is very interesting, as for your question I have no clue. Maybe to take strain off the motor, but looks like to be if your wheeling you have a very good chance of pulling the wires out. I truly don't know!https://www.jegs.com/i/Powermaster/...riteo&utm_medium=cpc&utm_campaign=retargeting.
Sent from my SM-N960U using Tapatalk
In circle track, you want weight on the rear for forward bite. And belts on the engine can be knocked off by stuff flying around under the nose. I guess it could be argued that it'd be harder to get knocked off by debris mounting like this. As for RPM, these things are tiny and don't make a lot of amps. I have a 35 amp version on my Cub Loboy Tractor and its a one wire alternator. Spin it fast or spin it slow, you get good voltage. https://www.youtube.com/watch?v=50K29CzLU1c
On related note, I've thought a little about mounting an oil pump there for positive oiling while running an upside down third member... #homemadehi9
Why would you run it upside down?
It gives (a little bit) more ground clearance for the pinion. Search for “high 9” or more specifically “true hi9”
My thoughts were flux capacitor at first..
I'd like to see a #homemadehi9 build. I'm curious to see how one would avoid inadvertently turning all of your forward gears into reverse gears.
