reamesc
have a RAT 3 spd original transmission in great condition- transmission was removed in late january to upgrade bronco with an nv-3550 transmission was driving very well when taken out, i just had my clutch fork bolts break off because of the PO that mocked up a racing bell housing with cheap bolts to hold it on. i only replaced the transmission when i had the clutch problem because it wasnt fast enough to get me to eufaula and back without screaming rpms.
also for sale is a flywheel clutch and pressure plate combo that is in working order and looks like it has barely any wear(i dont know when it was replaced b/c i just bought the vehicle last year). the clutch combo works on both the 1987 f150 engine in my bronco as well as the engine from 1972 it was supposed to go on. i also have a crossmember for a stock d20 and i have the adapter for the d20 as well. i would recommend replacing bearings in the adapter though. i also have a steering linkage that i recently replaced that needs new tie rod ends but is in good condition otherwise. lastly i have a hurst floor shifter kit that shifts smoothly, has reverse light switch, and has a floor cover.
transmission-$175
clutch combo with flywheel-$75
crossmember & adapter-$75
steering linkage(1972)-$100
hurst shifter kit-$125
will sell whole lot for $500 will consider trades, local pickup, will post pictures soon or as needed
transmission-$175
