68 Bronco Sport
- Feb 4, 2011
- 88
I am in the process of restoring my '68 Ford Bronco and need to make room for more parts. The following is what I have available and the only parts I have available at this time:
- RAT 3-speed with Duff floor shifter, clutch plate, dust cover, etc... (Worked fine when I took it out to swap in the AOD): $250 obo
- Dana 20 Transfer Case with Duff shifter (Worked fine when I took it out to swap in NP205): $250 obo ($400 for 3-speed and Dana 20 together)
- Early Bronco Radiator (Used Condition & may be original since was on my Bronco when I bought it): $65 obo
- Early Bronco Steering Column w/ Steering Wheel (Used Condition: Steering Wheel is cracked and previous owner crudely cut-off 3-on-the-tree shifter & linkage): $75 obo
- Edelbrock 1405 4-Barrel Carb (Worked great, but switched back to two (2) barrel carb): $75 obo
- Rochester Q-Jet 1524 4-Barrel Carb (Worked when removed from Chevy 350, but went another direction with project): $200 obo
- BW 1345 Transfer Case (Worked when removed from 1986 Fullsize Bronco): $125 obo
- Oversized Yokes from NP205 (Possibly 28 Spline 1350, but please verify, since I only know that they are bigger than 1310): $50 each or $90 for the pair
See pics of items here: http://www.flickr.com/photos/25809178@N04/sets/72157621817225362/
Local pick-up and serious bidders only. I am not very motivated at all to ship any of the items, so if you are out of the area, the shipping cost is up to you and it is up to you to motivate me.
Thanks,
Brian
(408) 673-1699
Thanks,
Brian
(408) 673-1699
