dprio34
Well, the rig is back from the paint shop. 3 Speed Transmission and Dana 20 have been rebuilt. Now is the time to get them back in. It's been several months since I pulled everything out, and my memory isn't as good as it use to be. Anyway, this is where I'm at.
I dropped the 302 in yesterday. I bolted on the Luk Clutch and Bell Housing in today. Now I have more of a technique question.
It seems most people bolt the transmission to the spud & the cross member all as one "assembly" and then jack these up all together and bolt into the frame.
Then stab the Dana 20 on last by itself.
I just want to confirm this is the best/easiest way to do things by oneself on the garage floor with a transmission jack.
If there is an easier way or preferred way, I'm all ears, especially for any "gotchas".
If there is any special gear the transmission needs to be in, or hints on how not to loose needle bearings, or any other suggestion, most appreciated. Gonna try to get it all in tomorrow.
Thanks in advance.
Don
Thanks in advance.
Don
