71 SPORT
third time i replaced the rear driver side seal and continues to leak, along with a grabbing feeling and noise when i turn.
i had my mechanic remove the pumpkin and inspect the gears and inspect the outer bearing which are both fine so he replaced the outer seal and it still leaks and same grabbing feeling and rubbing noise when i turn.I have the big bearing axle with posi (stock) any input would be greatly appreciated.
