BRussell
I have the front disc but know I want some rear disc brakes. I know all of the major vendors have them so what would be my best choice?
moabbronco said:I did my rear disks on my own. I bought the brackets from speedway motors for $10.95 apiece plus shipping of course. Picked up some "85 cadillac rear calipers from a junkyard, bought some rotors at the same junkyard off of a '79 f150. and bought the lines from NAPA. I think I spent $150 or so and they work great.
NAPA rotor #85-611
Rear hoses #BH36761
Caliper Rear left 242-2100
Caliper Rear right 242-2101
Speedway motors caliper brackets #91641010
disk pads AE 7070 RM
by the way this is the same rotor as the front on the 76-77 early bronco and most early model f-150's 1/2 ton of course.
medium duty housing
No but they are along the same lines. The Explorer ones have a backing plate that is the full diameter of the rotor.73stallion said:are those explorer disc brakes? they look like them.
The Big Bearing housings come with 2 different patterns on the housing ends. Actually Dutchmans sells the kit to fit either housing. The one most often referred to as the Medium Bearing is identical to the other one except for the housing ends which use the Torino ends which is identical to the pattern on the Explorer Rear Disks. (And some other newer 9" Big Bearing axles) If I recall right the backspacing on the Medium Duty axle (74/75 I think) is correct as well. For the one most often refered to as the big bearing (only in the EB world) the backspacing I believe is incorrect requiring different axles. As for the kit several places sell it and Wild Horses sells a kit that also includes the axles. For the Motorsports kit by itself it usually sells for about $400. I bought mine from Dutchman Motorsports for $390. (I also got my 35 spline axles there as well) Summit also sells the kit and I think Complete Off Road and Currie Interprises do as well. The kit is exactly the same thing as the rear disks on my 97 Explorer with the only exceptions being an added preload spacer on the axle to make up the difference in the backing plate thickness and the rotors have the 5 x 5 1/2" pattern drilled in them. (I could literally pull them off and put them right on my Explorer) I chose the kit though because the cost of doing a junkyard shop was within $100 by the time I counted new calipers, pads, etc. (Others here have done the junkyard swap) The Explorer brakes bolt right to the end of the axle if you have the big bearing that uses 3/8" bolts (Torino ends). If you have the big bearing with the larger bolts then you can still get the kit with the right pattern from Dutchman Motorsports. (Others may also drill it for the large pattern as well) The reason for needing new axles with this kit is to get the right backspacing. It might not be necessary with the housing using Torino ends.mrcat88 said:What do you mean by that? Big Bearing? And where do you find this Ford Exploder kit? or is there one?
I'm exploring rear disc options also, and I know of three, I think.
1. BC Broncos kit
2. JBG has a kit from TSM I think
3. Various weld-on brackets from various racing suppliers.
I like the bolt on stuff, since I can't weld. I also already have some of the Caddy calipers that I scored at a junkyard.
What about these? Anyone think they will work?
Ebay Disc Brakes
Yes they are tin. I should go to the garage and look at the backing plate sitting there. I have one that the backing plate came off when I accidentally put the ebrake to the full torque test. I was in low/low range (4:1) in reverse and 4WD and I kept pushing on the throttle when it wouldn't move. Eventually it did but it sheared the pin off the top that hold the shoes on when it did. (Proof positive that the ebrake holds extremely well because something was bound to break under that much torque) $45 later for a junkyard backing plate and I again have a working ebrake. I'll run out and get a pic of the one out there and do a comparison.73stallion said:that's what i thought too, but aren't the dust shields tin that can be cut off?
Just to throw another wrench into the machineryBRussell said:I have the front disc but know I want some rear disc brakes. I know all of the major vendors have them so what would be my best choice?
SaddleUp said:If you have a medium duty housing or are also considering upgrading the rear axles to 31 spline then the Explorer (Motorsport SVO kit) rear disks are a good option. The parking brake in them works better than any of the other rear disk options I've seen.
depends on the type of rears you are looking for.Mark in Memphis said:Walker,
I read your tech article about the Lincoln brakes and they sound great. Do you know what range of years to look for? TIA
Mark
